RLS7201
Aug 03, 2013Explorer II
mrlightrail wrote:WyoTraveler wrote:
I had an 89 with same setup. Both should run with generator. When that works then run an extra cord from the generator compartment. I would plug one into 30 the other into 20. I could run both on shore power. Easy to wire up that way because wire just runs from generator compartment.
Yep, found the switches, and the rear was off. Now running both on the genset. Would love to get the diagram for setting it up to run on shore power. Will be needed badly in these Okie summers.
John,
My 95 Bounder was wired like you MH. Here is how I now run both ACs on shore power.
Richard
38,769 PostsLatest Activity: Apr 03, 2026
