924guy
Apr 27, 2015Explorer
I built the solar kit from parts i collected off of ebay over time. after doing some research i decided to bolt the panel to the ac shroud and also use the a/c wire routing for the panel wires, worked out well. I had the new electric refrigerator running on high , off the battery for the past two days with only the panel to recharge it (in partial sun.) The voltage dropped to 11.8, a >2v drop is not bad for a 24 hr a day draw. with other accessories running, I may need more power so ill likely install another panel, well see how it goes.
