rgnprof
Dec 17, 2014Explorer
A quick update: I jacked up the rear and went to adjust the drums, but they seemed spot on - wheel turned with considerable drag (maybe too much, but I'm no drum brake expert) so I didn't mess with them. I then tested the ABS valve by pulling off the cap, removing the spring, replacing cap and pumping the brakes - the piston did not move, so I'm thinking my ABS valve is ok.
Sound right so far?
Ryan
Sound right so far?
Ryan
38,782 PostsLatest Activity: Sep 10, 2026
