apacheco
Feb 28, 2014Explorer
both batteries are 6 volts and are measuring the proper voltage when disconnected.
both batteries are brand new
when measuring voltage I have
6volts on each battery
6 volts pos to pos
6 volts neg to neg
0 voltage from outside pos to outside neg
circuit breakers blew when I put batteries in backwards. I reset them.
fuses tested
both disconnect switches click
cannot find any fuses on the converter.
what's the proper way to test for voltage on the disconnect coming from the batteries?
6 volts pos to pos
6 volts neg to neg
fuses tested
