tommy_g
Feb 28, 2014Explorer
apacheco wrote:I'm sorry to say that I can't understand your measurements. You have both 6v reading accross + to -.If they are wired in series, the two 6v readings should simply add up to 12v. Until you have said 12v, none of the other testing will be applicable.
both batteries are 6 volts and are measuring the proper voltage when disconnected.
both batteries are brand new
when measuring voltage I have
6volts on each battery
6 volts pos to pos
6 volts neg to neg
0 voltage from outside pos to outside neg
circuit breakers blew when I put batteries in backwards. I reset them.
fuses tested
both disconnect switches click
cannot find any fuses on the converter.
what's the proper way to test for voltage on the disconnect coming from the batteries?
