tahiti16
Feb 28, 2014Explorer
Positive to positive and negative to negative should measure 0 that should NOT make a circuit. You also stated that when plugged in or engine running you measure 12 at the 1 pos and 1 neg, this says everything outside the battery compartment works. One possibility is one of the 6 volt batteries is wired in backwards???
