RustyMacIntosh's avatar
RustyMacIntosh
Explorer II
Feb 07, 2020
95 Bounder 34J--rear leafs--shop recommendation
I took the Bounder to a shop yesterday to have the front end aligned. It was not far off, but it did need a bit of adjustment. RF tire was at 120psi. The front axle is tight. No issues. KYB up front, Bilsteins in the rear.
The overhang is a concern. That rear swing.The overhang is a concern. That rear swing.
Shop recommended that I have them add extra leaf spring in the rear to bring the back end up higher. Fleetwood in their ultimate decision to put such a long extension on the frameset the ball in motion back in the late 90's.
My quote was about $1300 or so.
The question is why can't we do what we did as kids. Add shackles. Raise the rear up by adding longer shackles?
I am going to talk to a spring shop today about building me several leaves, then have my regular man put the leaves in the rear, if I go that way. The shop I was at yesterday does brakes and big rig front alignments. They had several Class A pushers in there doing brakes, they seem to be competent.
But I have a local shop that does most of my automotive work. It is just getting 34ft Motorhome in and around into his shop and business.
So what do you all think? The shop yesterday said by getting the backend up higher and more weight on the front suspension, it might drive better without being pushed around by large trucks as they pass me.
Bounder from a distance in Paso Robles California last week.
https://postimg.cc/jLP219Qw
