Rustydog
Aug 01, 2013Explorer
A partially plugged radiator will cause that problem. When you are climbing long grades your engine is putting out lots of heat and the radiator can't dissipate it. A good radiator shop should be able to diagnose it quickly. Getting it out is an other issue, isn't easy I have done it twice, some coaches are easier than others.
I just noted that you have already replaced you radiator.
38,780 PostsLatest Activity: Mar 30, 2014
