MountainAir05
Aug 18, 2018Explorer II
jgonzales11 wrote:
Anybody know the brake bleed procedure for the tag axle on this model?
I have looked at all my old manuals and none have what you want. All I can tell you is if you have a vacuum source then use it to suck the old from the brake cylinder till you get clean fluid coming out.
First do the same on the Master cylinder and suck that out and put in clean and use a a small brush till you get it clean then start out with clean fluid. Then suck it thru the system to the wheel cylinder till all that is clean. You should have a very good bleed.
Just looking at what I sent you need to check the valves for sticking or rebuild if need. If you need parts then you will have to call the people who put it together. There were names and phone numbers on that pdf.
