builder1
Mar 23, 2014Explorer
Thanks for the tips. I checked the fuse links and both are good. One was 12ga going to the alternator and the other was 18ga, but not sure were it is going. Both checked good. I Checked the connections, both ground and 12v, all good. I also have replaced the solenoid. All works great on the bench and if I use a jumper wire from the battery to the starter switch terminal on the starter relay. Headlights work, but not turn signals, windshield wipers or radio that I noticed. It acts like a fuse is blown, but I can't find a bad one any where. I checked all in the fuse box under the dash and all in the power distribution box under the hood. Where does the starter switch wire come from before it gets to the starter relay?
38,769 PostsLatest Activity: Apr 03, 2026
