nickmae
Apr 05, 2014Explorer
96 f53 starter problem
I was having a starter problem and installed a new starter. when I try to start, It engages but doesn't crank the engine and sounds like it would with a nearly dead battery. the battery is new and fully charged, all connections are clean and in good condition and I have also cleaned all the ground connections. I've been trying to find
the wiring diagram to check any other components between the battery
and the starter that might cause this problem such as a relay or solenoid besides the one on the starter. Any info would be really appreciated. Thank you.
