- olfarmerExplorer III think 1995Brave is right, We had an 1987 Itasca and the pump was under the bed. On our 2001 it is in an outside compartment on the passenger side. Stim may be correct a valve may be open or sometimes it is hard to get the pump to prime after they have been drained to winterize them. Keep trying and you will figure it out.
- Your water pump should be located under the bed on the passenger side. Lift up the mattress and there will be a hole in the wood where you can see the pump and drain valve.
- StimExplorerIf it has not been used since being winterized it probably has a drain valve open.
