Mile_High
May 06, 2017Explorer
You don't happen to have a switch in the panel that says "slide lock" do you? Our full wall has a slide lock at the top that is electric.
Other than that, it could sure be the slide topper is jammed in there. See if you can unscrew the brackets from the slide and try the slide without the topper.
