CVD's avatar
CVD
99 ISB, Won’t Start After Filter Change
I changed both fuel filters; now will not start. Priming via Cummins instructions didn’t help. I then vented the lines via the banjo bolt going into the filter canister, still cranked without starting.
Details:
After changing oil, I changed the fuel/water separator filter (Fleetguard FS1242). Did not prime it (I normally do, but was distracted). Since I'd not filled the filter, I decided to start the engine before going to the other filter. It started immediately, oil pressure came up. As I went to the back to look at the fresh filter (to confirm nothing was leaking), engine stopped.
I figured I had air in the lines, so I proceeded to change the main filter element (canister on top of engine, Fram CS8941). I did not fill the canister, as I was going to have to vent the lines anyway.
I then cycled the key on, waited 30 seconds, off, back on. Did this a couple times and tried to start it – no progress. So, I then turned on the key, ran back to the engine compartment, loosened the banjo bolt going into the canister I’d just serviced, fuel came out. This makes me think I do not have air in the lines (I immediately tightened the bolt). I was working by myself, a 2’d set of hands and eyes would have been nice.
I then went to the first filter (fuel/water spin-on), to see if perhaps it wasn’t full. As I unscrewed the filter, fuel immediately came out the top – it was full.
Suggestions?
