Timothy2001 wrote:
The manual states that there is a swivel on the valve and pipe but I am not seeing anything like that and the angle of the hose is almost 90 degrees from the connection to the bottom of the compartment.
I know you solved the leaky hose with a replacement. The swivel that the manual talks about is that the connector pipe (between the grey and black tank valves) will swivel up and down so that it has more of a downward angle when dumping. When in the up position you do not have to worry about spillage when removing the cap to connect the hose if the valves leaked.
Mike
