mlslcan wrote:
Timothy2001 wrote:
I know you solved the leaky hose with a replacement. The swivel that the manual talks about is that the connector pipe (between the grey and black tank valves) will swivel up and down so that it has more of a downward angle when dumping. When in the up position you do not have to worry about spillage when removing the cap to connect the hose if the valves leaked.
Mike
Son of a gun! I've owned my 2005 Georgieboy for 5 years. The idiotic design had the hose always attached and inside a plastic box screwed to the bottom of the rv. Without the box (which cut the stupid hoses) the connection is right even with the floor and a bear to hook up. I read your post, went outside, and my y pipe swived right up to where I can leave my sewer solution and hooked up. Thank you, thank you, thank you! No more kneeling and struggling!
