Executive wrote:
I'm curious about the ice maker line replacement. It's my understanding the fridge has to be pulled out to access it. Or, are you referring to a residential fridge.???..if you're talking about a Norcold, I'd like more info. I want to replace mine.....thanks...Dennis
I'm interested in it too. I replaced the small tubing from the shut-off to the solenoid because it became brittle and broke apart. I imagine the tubing behind the fridge might be hardening. It's thicker but is exposed to the heat behind the fridge.
