lj2654's avatar
lj2654
A good RV repair place?
I thought maybe I would find an honest, knowledgable, repair facility after purchasing a DP four years ago.
I have had my coach at four different service facilities now and none have really been up to par!
1). One was supposed to replace the overheat temp sensor (black box) and gave me the RV back with the old box removed and wires hanging loose. They never installed the new one. I drove home and tried to turn it on, nothing. Then they sent a tech to the house to do it two days later.
2). Same place I had work done on my living room slide not opening properly(slow). Said it works fine. Got it back and left three days later to go to the Keys. Made a right turn after leaving the house and slide opened all the way up on its own. Almost caused a bad accident. Called them(Saturday) told me to bring it up to them (2 hours away) no apology no nothing. They never checked the hydraulic tank after troubleshooting and it was empty.
3). Same place again, went to pick up RV and there was a two foot long gouge on passenger side of coach down to the bare metal on trim rail. Their response was, it must have already been there. Freshly done by appearance.....had to leave coach for three weeks for them to repair damage.
4). Now DP at another facility(highly recommended) since the end of August. Still there because of an issue I didn't have when I left it there. I did tell the shop foreman they could take their time on it. But I needed it back the beginning of November for a planned trip.
A/C compressor replaced/receiver dryer replaced/condenser motor replaced/serpentine belt replaced/water pump belt replaced/rear wheel seals replaced/thermostats replaced/
Now after they test drove the coach it overheat temp 225. Has never been over 210 in the four years since I purchased it. They now say it is a clogged radiator and want to remove it$$$ and send to a radiator shop to clean. During the removal called me in. Showed me some of the insulation that had came loose from above radiator and lodged between radiator and CAC, 95% sure that is the issue. Still no word in two more days and the weekend is here(21st). Supposed to leave 25th for Thanksgiving, not going to happen because of their time usage.
I just want a service place that is honest, labor rates fair, have qualified mechanics that know what they are doing! Is there such a place or am I dreaming!
Replies have been turned off for this discussion
  • I would recommend Alliance Coach in Wildwood. Have used them on two occasions
    and have been very satisfied. First was a big job--replacing bathroom floor
    due to unknown water leak at the drain location. The other was normal routine
    maintenance before hitting the road.
  • sdianel wrote:
    We use Cummins in Ocala. Never had a problem with them. We also use Alliance Coach in Wildwood. I would put reviews on www.rvservicereviews.com for those that didn't provide good service.
    I have put reviews on RV reviews already, except for the one that has coach now!
  • Have you tried Alliance in Wildwood, Florida? It used to be a very busy place before when it was the Monaco shop and they had all those recalls on the Safari coaches.
  • We use Cummins in Ocala. Never had a problem with them. We also use Alliance Coach in Wildwood. I would put reviews on www.rvservicereviews.com for those that didn't provide good service.
  • Second the J and L.
    Reasonable prices and Joe thinks his way thru first. Most competent I've met.
  • If you make it to Southern Cal:
    Covina Diesel for engine work.
    J & L in Fontana for anything non-chassis.
    Both of these establishments meet your criteria.
  • +1 on Lazydays.
    We've had very good service from them, but do have to put up with scheduling it.
  • I just want a service place that is honest, labor rates fair, have qualified mechanics that know what they are doing! Is there such a place or am I dreaming!
    Yes there is a place.
    STOP taking it to dealer and repair shops!!!
    Call an RV Mobile Repair man. They are more knowledgeable than any mechanic I have ever seen in an RV repair shop. Rates are FAR more reasonable than the highway robbery that occurs at the repair/dealership shops. AND your MH is fixed in one day right in front of you!
    You never have to leave your MH anywhere ever again. They come to you.
    Half the time they have the parts needed right on board their truck. If not they order it and get it 'the very next day' and they are back to fix your MH. I've seen them get parts the next day that no one else can even get their hands on!
    I also have ALL my maintenance work done by them also, on site.
    Once I found out about Mobile RV repair I have not looked back, have never been without my MH in over 7 years on the road. Call Mobile Repair, pull out a lawn chair, sit down and open a cold one while she's being fixed.
    Just can't say enough about them. If you are in a CG ask the CG owner who 'they' use for RV Mobile repair. If you're not in a CG find the closest CG to where you are at and ask who they use for RV Mobile Repair they will come out to your house also.
    Once you use an RV Mobile Repair service you will never take your MH to those money grabbing, incompetent, you gotta leave your MH for 4 weeks for an oil change, repair shops ever again! :B
