vincentru
May 29, 2014Explorer
thanks for your professional advice,
could I ask,how about your MH running while those 5 years?
If we do more homework,can make sure to find a good condition old?Class C?
maillemaker wrote:I am a newbie about RVing and a new driver,4person family(me,my wife and daughter3years and son 3months)
can I buy a 1979 Robinhood Dodge Class C for 3850 usd?
the seller said?
1979 Robinhood Dodge , H/D 440, * Gear Vendor Overdrive*, self Contained, 4..0 Onan gen, Headers, Ice Cold AC, Big 2 dr Ref, Nice bathroom, New Brakes & Bearings, New ft tires , New ft end + aligned, Everything Works, Ready to Go anywhere ,...!!! Got $6,000 in it , take $3,500 ...!!! Last trip to Wyoming no problems ...!!!
in fact,If I buy ,I need pay how much when we need to use it to travel?
Hi Vincent,
My family also has an older RV. We have a 1990 Winnebago Warrior we bought about 5 years ago.
Lots of good advice above.
Firstly, Google "tire date codes" and learn how to read the date codes on the tires. As was noted, RV tires seldom get enough mileage to wear out the treads, and instead age gets them. Manufacturers will tell you 6 years is about the lifespan of tires. Driving on older tires risks a blowout and when these tires blow out if they disintegrate they can cause massive damage to the underside of the RV. I had a friend with a 5th-wheel who had a blowout and it destroyed his hot water heater and took out his black water sewage system.
Always check your tire pressure before you get on the road.
For the RV you are looking at, trust your nose. If the inside smells like rot or mildew, you've probably got a water leak problem that has resulted in rot. It can be very difficult and expensive to rip out what needs to be ripped out to get at rot and fix it.
Look at every single appliance on the RV and make sure it is working or start deducting from the blue book value. Things to check that work:
Oven
Stove
If RV has a built-in propane leak-down pressure gauge, use it to check for leaks by turning on the gas at the tank, then turning it off and seeing if the lines hold pressure while you perform the rest of your checks.
Make sure the refrigerator works on all the modes it is supposed to work on: Gas, 110V, and 12V (if it supports 12V). You won't be able to tell if it is working in all 3 modes (takes too long to get cold, warm back up , and get cold again) so get it in writing that it works in all modes.
Fill up the water tank and make sure that the water pump works and shuts itself down when it pressurizes the lines. If the water pump won't shut itself down that is a good indicator of a leak. If it periodically keeps turning on, it is a good indicator of a leak.
Check all faucets for function.
Check that the water heater works.
Check all lights.
Check batter/water level indicators.
Check that electrical items work when plugged into shore power and when on house battery.
Check that the generator runs with a load inside like the AC running. Make sure the generator can run for at least 30 minutes without shutting itself down.
Make sure the cab AC works. If it doesn't it is old and will have to be converted to the new R134A refrigerant.
Make sure the toilet works.
Steve
38,776 PostsLatest Activity: May 15, 2026
