- Argosy24Explorer
Doc Eagle wrote:
Will try from now on out, previous owner could get 10-12 MPG, guess she kept the speed down.
I think she kept the BS level up. With the weight and frontal area of a MH, axle ratio, and technology of a 454 she was always driving downhill with a tail wind to get 12 mpg - Doc_EagleExplorerLooking to increase my MPG, from what I understand the best RPM range for a Chevy 454 is about 1700 RPM. Of course can't stay in that range and cruise at 65 to 75 MPH! Will try from now on out, previous owner could get 10-12 MPG, guess she kept the speed down.
- BULLETLS1ExplorerThanks DAVEINET for clarifying the pic!
thank you all for the comments, yes it had a odd brake light,
I found a diameter cutting tool, and a milling machine, after much consideration because the cluster connector was in the way of the cutout, I will need to find a 12 pole male-female connector, but that's easy, the rear of the cluster has a plastic flexible printed circuit that will be done with regular wires individually.
tried to keep the tacho face away from the glass just a fraction away.
glued with black silicon.
hope you like it!
If I could cram a 737 hardball cockpit in my RV I'll be a happy man! HAHAHA! - magik235ExplorerLooks clean
- glamisorbustExplorer III need to add one to mine also, should have came with one from the factory.
- FuzzyKnightExplorerNice
- Doc_EagleExplorerMan, that looks great! Going to add one to mine, a 1993 22' Fleetwood Flair on a P-30 chassis.
- Argosy24ExplorerThe emergency brake light on mine.
- DaveinetExplorerNo, this is what it looks like :) :
What was there before? - I used a 2" tach and one of the already punched holes in the dash.
38,773 PostsLatest Activity: Apr 23, 2026
