tropical36
Dec 01, 2017Explorer II
Spizzer wrote:
All,
Thought I would post a thought I had that goes against what everybody does:
Conventional wisdom and recommendations say to change your oil after you have brought the engine up to temperature. The idea is that all the particulates that have settled in the pan get mixed up into the oil so that when it is drained you get a cleaner result. The problem with this is that the oil is dispersed throughout the engine in all the oil-ways and up in the rockers, etc. So theoretically, the most "complete" oil change is done after the engine has sat for an extended period of time giving all the oil a chance to make its way back into the pan. (I don't think I have ever changed oil and had the old oil stop dripping out the drain hole.)
Now, on to the sediment issue....a while back, after an unfortunate event, (a story for another time....) I had to drop the oil pan on my Cat C7. The rig had been sitting for weeks without being started. I drained the oil and dropped the pan. I was half expecting to find some thick sediment in the bottom of the pan, but to my surprise it was sparkling clean with just a thin layer of oil in it.
So, in light of this, it made me wonder if it is not better to do oil changes on cold engines? Running the engine just disperses the dirty oil of which some doesn't get drained.
What do you think? If you abuse your oil and don't change it regularly, then the sediment/crud issue could be a valid argument.
BTW, I have been doing all of my yearly maintenance and just changed the oil today. What did I do? Ran it around the neighborhood until it was hot and then changed the hot oil! Hard to stray from old habits.
I would be interested in hearing others thoughts on this.
Regards,
jeff
Had this same thought and changed one cold. Not that it's what you call cold, in the tropics. Then with reading some, I got talked out of it. After reading all the posts in this thread, I think I'll go with a cold engine, this next time, which will be pretty soon and with trying out my new low boy draining cart.
I could always use the block heater for a few hours in the morning, if need be and since I don't do much these days, until after lunch, anyway.
