lj2654ExplorerSep 15, 2017ABS wiringDuring the evacuation for hurricane Irma I had a brake that got hot. The left front wheel ABS sensor end melted and came loose from the wheel hub. Where do you go to find these connections. I have a p...Show More
wolfe10ExplorerSep 15, 2017From the length of the wire from the sensor you should be able to easily find the connection.Pretty easy to pull and install. As I recall, only takes a pair of pliers.
Related ContentFleetwood Angler wiring2005 SixPac D850 WiringBad tail light wiringABS light.Ram truck ABS/HCU recall
