Scott___Jill's avatar
Scott___Jill
AC Fan
I had been using both AC fans just the fan not the AC for a couple days when I went to turn the front AC fan on it just hums and the fan dose not turn on dose anyone know what I should look for on this problem??
  • Would like to thank all of you for your response they were all good thing to check out Thanks again.
  • The fan in my 1999 Winnebago Chieftain would do the same thing, as well as shriek sometimes. Removing the cover and spraying some lube into the motor would free it up and work for a time. Did this many times over the last 2 years. It finally froze up and wouldn't restart. Copied the Manufacturer name and model # off the ID plate on the motor. Found a new one on Amazon. Replaced it. Now it runs like a champ. Should have done it 2 years ago.
    BTW, I had Camping World check it on my maiden voyage. They estimated about $1200. Turned them down. The motor I needed was only $179 on Amazon.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    ScottG wrote:
    Probably the start cap has failed.
    Suspect #1 that is
    Seized shaft
    Insect/bird next in fan/blower assembly jaming it
    And that about covers it,
  • If you have not service it (oil) that could be it or a start cap. Time to climb up.
  • I would go on the roof and check and see if the blower will turn freely. Make sure the breaker is off.
