- Have you read this thread? Did same on my pop-up ten years ago and it really helps.
Nevercold now very cold, east fix
Otherwise I would run the 2-way fridge on propane for best efficiency. They were designed to be run on propane with the 120v heater as a convenience add-on. - 2oldmanExplorer II..
- CA_TravelerExplorer IIIPlus if really hot run the ACs to cool the inside, but doubtful that it gets that hot is Salem.
- Sully2ExplorerSmall fans blowing fresh air up the stack where the reefer coils are. Brings my reefer down a solid 5 degrees
- midnightsadieExplorer IISCV said it all. when first starting 24hrs before you load it,, put a gal jug of frozen water in, it will help reduce cooling time.
- Ka_RonExplorerWe just let it do its thing.
we have a Dometic fridge and it keeps up quite well weather on A/C or propane.
If it is really hot we try and use the air conditioner to keep the inside of the motor home comfortable, but if boondocking, the fridge keeps up quite well. - SCVJeffExplorerRefrigerator
Please edit the subject..
-Don't open the door
-Keep the fridge side of the coach out of the sun
-Use an internal fridge fan
-Add cavity fans if needed
38,709 PostsLatest Activity: Mar 12, 2025
