TyroneandGladys
Jun 29, 2013Explorer
garyhaupt wrote:
In the years that I have been an RV Net member, I don't recall ever reading about A/C's shutting down due to heat issues. huh...I am sooo glad that I am not in Needles or Barstow or the Mojave right now.
Gary Haupt
Condition called High Head Pressure can cause a AC to shut down.
High head pressure is due to the lack of heat removal during the condensing process of the refrigerant cycle. The AC could be removing enough heat when it is only 95 but unable to remove enough heat at 115. If the coils on the roof are dirty or blocked this can cause High Head Pressure.
I have personally experienced generator shut down from high temps while parked and under high temp conditions I will leave the generator compartment door open and try to shade that area of the RV.
38,782 PostsLatest Activity: Sep 10, 2026
