tatest
Jun 29, 2013Explorer II
Depends on what you mean by "the inside won't get cold." Are you trying to get it somewhat cooler than the outside, or are you trying to get it down to what your would consider cool in the PNW? The latter isn't going to happen.
I've found very few type C RVs that have enough insulation and cooling capacity to get down below 80-85 F in full sunlight, even if the air outside is only 105 F. At 115 F, the A/C is even less capable of throwing off heat to the outside, trying to cool the condenser with air that hot.
If you are in full southwestern sunlight, don't expect much more than 20 F below the outside air temperature. But things should work a lot better in the shade, and at night, you might get the inside as much as 30 F cooler than the outside air temperature, assuming that has dropped for the night also.
FWIW, when I've lived in hot summer climates, I like to set the A/C no more than 15-20 below the daily high. Otherwise, going inside to outside is too hot, outside to inside is too cold. You acclimatize, often in a very short time.
Right now, sitting on the porch, sun down, temperature down to 83, a little wind feels like a cool breeze, after working in the sun all day with temperatures in the high 90's. Inside thermostat is set to 80, and air coming out of the vent gets so frigid I'll sometimes use a lap robe, because I'm dressed for summer, not winter.
38,782 PostsLatest Activity: Sep 10, 2026
