GreenMtMomma's avatar
GreenMtMomma
AC not working
2017 Jayco Redhawk 29xk
Put on generator - try to turn on cabin AC but does not work.
New RV HEEELLLPPP
  • Does your power cord need to be plugged into your generator?
    Some do and some don't.
  • have you checked the breakers on the generator? should be outside on the front of the generator.
  • AC in RV area not working - does not turn on at all... AC in ford can off dash working.
  • Book says very little - generator working - thermostat set, lights working... Generator breakers ok
    Are other breakers near battery?
  • got a book ?.does other lights ,light? did you check the breakers? did you check breaker at the gen set? did you set the thermostat?
