Pop-Pop_CExplorerApr 14, 2016AC ODORWhen we run the heat pump we are getting a musty odor. Have seen this discussed before. Was wondering if a 50-50 mix of bleach and water sprayedon the cores would be a solution, or use a vinegar sol...Show More
wolfe10ExplorerApr 14, 2016Use an EVAPORATOR CLEANER-- available at any box store.Service is done from the roof. Remove the A/C cover and then the cover to the evaporator. Be sure to block access to the interior before you spray/rinse.A tooth brush (NEVER your own) is a handy evaporator cleaner tool.
