gssfc's avatar
gssfc
Ac on generator problem.
We have a 2014 Georgetown 351ds with dual 15k ac units and a 5500kw generator. When on shore power both ac units operate fine cycle as they are designed and blow cold air. When on generator if both units are running they will run for a short period of time (10-15 min) and then suddenly shut off as if they lost power but the generator does not seem affected…it doesn’t bog down or trip a breaker. Solution is to shut off the ac at the thermostat and then restart and it works fine for a 10-15 min then both shut off again. If we run only one ac unit there is no problem. Will run for days without issue but neither is sufficient to cool the motorhome down.
Kind of lost as to what’s happening.
  • I would start by checking the voltage output of the genset. Check with no load and then with both ACs running. I think you may find that the genset set is not putting out enough voltage. It may need a throttle adjustment.
    What is exact make and model of genset.
