Rick_Jay
Aug 23, 2023Explorer II
wpatters1229 wrote:
I have two meters one being a fluke. I also have a degree in electronics. But was not sure of how the RV deals with this A/C problem. I did figure it out and all is well.
So, I guess all is not well?
We're trying to help you, but you haven't responded to the questions we asked to help you diagnose your problem. I'm still leaning toward then 20A to 30A adapter.
Can you tell us what voltages you measure at an wall outlet inside the motorhome when the A/C is running? It would be interesting to compare these readings on a cooler day and then again on a hot (90+) day, and several times, not just when the A/C is first turned on, but after it's been running for a while. I suspect the voltage at the A/C is sagging under the higher temperature conditions enough to trip the 20A breaker.
"I have an adapter for 30 to 20 and a 10-12 ga extension cord." Is the adapter for a 30A plug (male) to 20A receptacle (female), or for a 20A plug (male) to a 30A receptacle (female)? The latter would allow you to use your 30A RV shore power cord on a 20A outlet. The first one would allow you to plug a standard 120VAC extension cord into a 30A RV receptacle.
You say a "10-12 gauge extension cord"? Which is it, and how long is it? How old is it and does it appear to be in good shape? Do the connection ends get hot while it's being used while being used?
I'm not sure what you mean with this: "...and am also taking the unit out of the wooden box in the RV to check the fan." What unit out of what wooden box?
"Does anyone know how to test the Fan since it comes on via the controller board? Is it a 12v fan or a 120v fan?" Are you referring to the fan on the A/C unit? If so, I believe that should be 120VAC.
If you're trying to run your entire RV off a single 20A connection, be aware that other appliances in the RV might be adding to the current draw in addition to the A/C, unless you're specifically turned them off. Things such as electric water heater, refrigerator, battery charger, TVs, etc. With only a 20A supply, you should be able to get the A/C to run properly, but only if ALL other draws on that 120VAC line are shut-off. Again, AC voltage measurements inside the RV would go along way to help diagnose this. A voltage measurement without the A/C running, then one with it running, and then several other with it running at various times during the day and different temperatures.
Well, good luck. Any specific troubleshooting info you can provide (voltage measurements at various operating conditions) could be very helpful.
~Rick
