We shouldn't be guessing, but here are three guesses:
1. Another GFCI somewhere. Some appliances will trip a GFCI while being turned on or off but not if plugged in while switched on. We have two identical little fans. One trips GFCI if turned ON while plugged in, the other does not. Runs fine if plugged in with its switch ON.
2. Partially tripped Breaker. I don't like this guess because a big residential vacuum's about 08 Amps, and a TV is more like 01. Now if some other appliance is on that breaker, then sure, vacuum might trip a 15 Amp breaker.
3. Fault in the coach wiring, like a failed connection at breaker or outlet.
For ALL these reasons, I think you need to do whatever it takes to get an AC Wiring Diagram for YOUR Make/Year/Model. Then post it here and we can help better. Narrow down the guessing. The FR forums might help, if not, call the company.
