bigdave720's avatar
bigdave720
ac problems
While my ac was running the other day the power cut off and on several times right in a row. I don't have a surge protector yet. Now when I turn on the ac it makes a lot of strange rattling noises and seems to be getting slower as it runs. Did the power problem kill my 26 year old ac or is there anything I can do to salvage it?
  • And also make sure you have adequate AC voltage if using the same plug in.
  • Thanks. I'll check that out this afternoon and let you know what I find.
  • I'll second looking at the startup capacitors. Usually if they're bad it will be visually obvious.
  • I would open it up and look at the capacitors. If you do, be real careful. They hold a charge for a while.
    Jose
