I am looking to replace this ac radiator that works with a fan attached to it that's is part of the ac system. I had a accident a while back and the ac radiator was slightly bent and now need to repl...
You'll probably need a compressor after two years open to the air. The components of the coolant turn to acid with the introduction of moisture from the atmosphere and destroy everything it touches. Don't even try to just install new parts and fill with freon, you'll just be wasting your money.
