imgoin4it
Aug 21, 2014Explorer
Winnebago basement airconditioners are famous for developing duct leaks in the area that goes up under the rear cap. It is very easy to tell if it is leaking as you can stick you hand up, at least part way, along the duct and if leaking you will feel the cold air. It does not take much of a leak to loose lots of cooling. I had the problem on a Winnebago and while at the factory and they had to take off the bottom portion of the rear cap to reseal the duct. I later had a smaller leak down low and sealed it from below and reaching up. If the leak is at the top, the rear cap would have to be removed to repair/ reseal.
38,769 PostsLatest Activity: Apr 24, 2002
