lacofdfireman
Jun 20, 2016Explorer
A/C runs for 5 minutes then pops breaker in 110 degree heat?
I have an 07 Georgetown with 2 A/C units. One in the bedroom and one in the living area. The A/C in the living area which is a 15k Dometic Brisk Air A/C and was replaced last year will only run for 5 min then the breaker pops. We have no had any issues until this week when the outside temps have reached 100 degrees plus. Any idea what could be causing this? We are plugged into 50 amp service in our home. Haven't tried it off the generator yet but would imagine it will do the same. We have tried both high and low fan with the thermostat at 70 degrees. No issues for the rear air conditioner. It runs and doesn't stop. Also its the original that came with the RV and is a 13.5k unit..
Any ideas or help appreciated. Not a good thing in the 1`0 degree heat..
