wa8yxm
Jul 24, 2020Explorer III
YOu said the slidout is not working but the lights are. That's strange
Most RV's the Lights are 12 volt and of course so it is the slide.
A list of other things 12 volt
A/C control
Furnace
Water pump
Refrigerator control
Water heater control
Fans (other than A/C)
Check your 12 volt fuse panel. Best way is a test light Ground the clip then probe the small square "Window" on the blade fuse Bright/Bright = Good
On the house panel dark/dark is major problem
Bright/dark or dark/bright = blown fuse .
A/C control
Furnace
Water pump
