B_B_Upch's avatar
B_B_Upch
AC went out after getting unplugged?
Hello again. Hoping to get some more help. It's been a while. So I plugged my rv into my 30 amp plug at the house & turned on the front AC to see if it would cool & get things ready for summer.. while it was running. My buddy & I went to check the 50 to 30 plugs(I had to replace the 30) to see if they were getting hot. They were fine but after I put them down it got unplugged & my AC went off.. so before I plugged it back in I walked inside & turned off the thermostat. We gave it a few minutes & I walked back out plugged the rv back in & when I went to turn the AC on nothing happens... the thermostat comes on but neither ac units come on.. no hum.. no fan ... nothing.. I checked the fuse at the breaker inside & it looks good. Any suggestions on what or where to look? Thanks
  • A/C's have a ten min time delay before they will restart. every time you interrupt the power it must reset and start the clock over.
  • Manny have a two minute time delay after you turn the power on.
  • Reset the circuit breaker. Did you unplug while unit was running? Bad idea!
  • What kind of thermostat? What kind of RV? What kind of a/c? What kind of shore power?
    We'll need a little information to be of any assistance.
  • Does the microwave work?
    Check the breakers in the RV--cycle them off and then on.
    Did you monitor the voltage while running the air conditioner?
