keramiller1980 wrote:
dougrainer, I thought the forum picked up my RV stats from the profile.  Mine is a 2008 Holiday Rambler Scepter 42PDQ with Dometic.  I believe that 1 is Forward (which is working), Zone 3 is the bedroom area (which is also working) and Zone 2 is for the bath and hallway area (which is the one not showing up on the thermostat.
I ALWAYS check profile. In your case, there is nothing on your profile that states anything.  Please recheck your settings.
Now, Zone 2 is GONE?  No 2 listed, or you have a Zone 2 and it shows no functions? Have you had any work done on the AC systems lately? If so, they may have neglected to set the DIP switches on Zone 2 or the other AC units. Your AC Zones are just like you listed.  Have you done a reset?  If not, here is the procedure. Once you have answered my questions and done the reset we can go further if this does not fix the problem. Doug
SYSTEM RESET
 After setting the dip switches in the electronic control
 kit, do a system reset.
 1. Turn the ON/OFF switch to the "OFF" position.
 2. Simultaneously depress and hold the MODE and
 ZONE push-buttons while turning the ON/OFF switch
 to "ON". FF should appear in LCD display until the
 mode and zone push-buttons are released.
 3. When a dip switch is turned on after initial configuration,
 a system reset will need to be done before the
 Comfort Control Center will recognize the updated
 selection.
