jbbrick
May 22, 2013Explorer
The accumulator tank just allows you to use a little water without the pump cycling on and off constantly. It gives you some cushion in the system so you can usually flush a toilet in the middle of the night without the pump going on, then when the pump does run, it stays on a bit longer to build up to its balance point. They really are handy.
