Dutch_12078
May 23, 2013Explorer III
The Revolution pump works fine with a 2 gallon accumulator tank. The pump cut-in pressure is about 30 PSI, and the cut-out is the expected 55 PSI with the factory settings, very similar to a standard residential pump setup. About the only difference I've noted with Revolution/accumulator installations is that the pump tends to run a bit longer as the tank pressurizes and the pump bypass valve starts to open before reaching the rated 55 PSI. The run time could likely be adjusted down a bit by raising the bypass pressure, but I don't think that's really needed.
38,782 PostsLatest Activity: Sep 18, 2026
