Dutch_12078
May 29, 2013Explorer III
Marv Hoag wrote:
I have installed the revolution water pump and have left the Jabsco accumulator at factory pressure of 20 psi. Everything seems to be functioning.
With the higher pressure pump (55psi)should I increase the pressure in the accumulator to 30 or more psi, or leave it as is?
The controlling factor for the accumulator static pressure setting is the cut-in point of the pump, not the cut-out at the high end. If the system is functioning to your satisfaction, I'd say leave it alone. Otherwise, you might be able to tweak the tank pressure a bit to increase the draw down slightly. Or not...
38,782 PostsLatest Activity: Sep 10, 2026
