dougrainer
Jul 30, 2020Nomad
Since it does the same thing on Genset, I would either test the Comp start capacitors or just replace them. They are cheap. The reason I would replace is age of unit and you have to go on top to gain access to the electrical box for the AC units. Go on top to get the part number of the Start capacitor from one unit and get the Capacitors and then go back up and then replace since you will be up there. Since it does the same on Genset, your Intellitec system is not a factor. Doug
