frankie32
Sep 05, 2016Explorer
Funnu Acting AC
I just did some mods to my ac unit swapping out ac vents in my ceiling withones that close. I have a total of 4 so no/ many areas of output. I have a Dometic 13.5 AC on my roof. Earlier I closed 2 of the 4 units and noticed after a while the AC turned off and the temp rised. Temp was set at 72 and was up to 78. I turned the unit down but nothing happened. I turned the unit off at the thermostat for a few minutes and turned it back on. This time the ac kicked on no issues. A few minutes later a loud pop and a few chunks of ice came from the 2 ducts I was using, not from the unit itself. A few minutes later it shut off again at 74 degrees (still set for 72) and would not turn on again. This time I had to run with the wife out but never checked it again. We came back to the camper this evening and it was set back to 72. I dont't know if the unit pulled itself back down or it just came down. The unit has turned on and pulled the temp back down since we have been back but am not certain if this is something I should be worried about or if I accidently froze something up. I did notice I have a every few second drip coming off the back even with the unit off.
Thoughts/ideas? Anyone else ever experience this?
