As others have said, when you block air flow the evaporator will freeze up. Doesn't matter what the thermostat setting is. Once the evaporator freezes the unit will shut down due to the freeze sensor. There's a reason TT manufacturers don't put closable vents in the air conditioner system. Most of them are border line ready to freeze up even with all vents open.
I see folks do the same with their heater ducts too. Then the furnace overheats and goes into shut down.
It's not like your home system. Those usually have an abundance of duct cross sectional area and some vents can be closed and still leave enough air flow. RV's usually have the bare minimum of duct cross sectional area required for the unit. Some don't even have that.
