fijidad
Feb 23, 2021Explorer
Well, this camera is not adjustable...so far as I can tell.
I removed the two screws holding the housing to the coach body, then found four allen screws holding the camera to the housing. I loosened all four and tried moving the camera inside the housing, and it moved not a bit. . So put it all back together and am now going to investigate installing another camera. Not entirely sure what that will entail, but likely a parallel system to the existing black & white original system.
38,779 PostsLatest Activity: Jun 16, 2026
