GdlowExplorerJul 26, 2020Add water to class A while boon dockingFor some reason the onboard pump works to transport water inside the coach, but won't when trying to use the suction port to fill the water tank from a non pressurized system. Anything I could check t...Show More
MountainAir05Explorer IIJul 31, 2020AS Dutch stated, Also if no wet spots in the compartment then you do not have a leak, just plumb wrong.
