- vjstangeloExplorerGo to IRV2.com, or forestriverforums.com, then find the Forest River FR3 forum. Many folks have done this very mod on their units. You might get helpful ideas.
- TxsurferExplorerI guess you only have to run it on the ceiling until you get to the cabinetry and it should be easy enough to take it from there.
- ScottGNomadI'm sure that's the worst part. You may have to use cosmetic-type surface mounted conduit if you can't fish it inside a wall.
- MrWizardModeratorI think , that if it is not pre-wired with second A/C option
You will need to go with wire mold on the wall and ceiling as you will not be able to pull Romex down to the basement thru the ceiling and walls - TxsurferExplorerThanks - I wonder how hard it is to pull some romex down to the basement?
- ScottGNomadShould work just fine if you can find a nice way to route the second power cord.
You'll have enough pedestal power anywhere they have a 100A panel, that is, a panel with 50, 30 & 20 amp outlets. (The 30 and 20 are on separate legs)
