rgatijnet1
Mar 02, 2020Explorer III
It is impossible to find two batteries that are identical. Just make sure that when you add the second battery that it is hooked up to provide 6 volts and not 12 volts and not 24 volts if you are paring two 12 volt batteries. Also make sure that the polarity is correct so that you have pos to pos and neg to neg. Unless the existing battery is already bad, the two batteries will soon balance out.
