pianotuna wrote:
tenbear wrote:
I don't know much about AGM batteries, but you probably have a lead acid battery now. It may not be advisable to have a lead acid battery and an AGM battery in parallel.
X2
On our RV we have two house batteries with one being under the hood and the second one in a battery compartment at the rear of the RV. The front battery is very accessible for maintenance the rear one is a pain since you have to remove the battery for maintenance. I did put a AGM battery in the rear and a standard battery up front due to the higher cost of AGM batteries. Four months now and no problems so far.
