mericksonjr wrote:
So I believe that maybe a smaller 750watt would work just fine to do that I will just have to figure out how to run the power from the battery to it.
Stick to 300 watts max as that is twice what is needed.
Use the existing 12v main power feed to the 12v panel to get 12 volts.
Then use a small transfer switch to power the single tv/dvd circuit.
http://www.donrowe.com/KISAE-TS20A-Automatic-Transfer-Switch-p/ts20a.htmNo pulling wire, just make connections.
Go Power 300w sine wave has a provision for a remote switch. No digging into hidden area to turn power on.
http://gpelectric.com/products/300-watt-pure-sine-wave-inverter
